Sastma
Jun 12, 2021Explorer
F53 Rear Sway Bar Bushings: Wrong Size
I ordered and just received replacement polyurethane sway bar bushings for 2010 F53. The problem is the replacements are 46mm wide and the originals are 50mm wide. The 36mm holes are find and would fit well except the mounting brackets are 4mm two wide.
What I ordered was supposed to fit 1999 - 2011 F53.
Where can I find the same size bushings (50mm)?
Should I just cut/grind 2mm off to fit the original brackets? The originals look much more robust than what comes in the kits.
Thanks!
Thanks!
[/img]
[/img]
[/img]
