mobeewan
Jul 15, 2014Explorer
I am over 300 lbs. When getting in and out of the bed and tossing and turning I tend to pull fitted sheets loose from the opposite side of the bed that I get in and out from. I found these sheet grippers and place them on the side that keeps pulling loose. They work great!
Instead of buying custom short queen sheets you might put regular fitted queen sheets on from the head of the bed first and after pulling tight at the foot of the bed slip the keepers on at the bottom foot of the bed and tuck the extra under the mattress. The keepers will only work if you have a bead around the mattress bottom edges. They work by pinching the sheet around the mattress bead. After pinching the sheet around the bead with your fingers you slide the keeper along the bead while pushing it over the bead.
About RV Newbies
4,032 PostsLatest Activity: Apr 08, 2026
