bikendan
May 12, 2017Explorer
bernercamper wrote:
Well I'll paste the info from the doorjamb sticker and the manual...
gvwr 6800lbs
gvwr frt 3400
gvwr rr 3968
heavy duty trailering equipment
rear axle 3.42 ratio
hd aux transmission cooling system
c-1500 2wd suburban 5.7l 3.42 max trailer wt 5,500lbs.
edited to add: rear bumper says max tongue weight 500 lbs, max trailer weight 5000 lbs!
None of your numbers show payload capacity.
It's listed on the driver's door yellow sticker.
But if your towing capacity is only 5500lbs, that really limits your choices.
Only a hybrid TT would have enough sleeping capacity and be in that weight range.
About RV Newbies
