pitch
Aug 22, 2015Explorer II
The silver is an uncoated steel the gold is cadmium plated. There is no difference. What is the application? You need to use a nut that is equal in properties with the bolt or stud.
In other words do nut use a 2 or a 5 on a grade 8 bolt. Do not use aluminum on steel or vice versa.
Is this a shear application or a compression application. It all makes a difference.
Perhaps if you describe what you need to accomplish you would get a better answer. RV.net does not charge per word! go ahead free your mind,expand and expound on he subject at hand
About RV Newbies
