Turtle n Peeps wrote:
I have been camping in TT'ers for over 45 years.
I have dumped when full, dumped when used 1 day and everything in between. I have NEVER had any problems; EVER. 95% of the time we just use the trailer for 1 day and when I pull into a campground with full hookups I dump.
I don't know where this odd idea came from that you can only dump when full. It's just bull pucky.
I mean really, think about it. It's just a container; nothing more, nothing less. I may run 5 or 10 gallons of water in the tank and then I pull the handle.
The way some people on here make it sound it's like your trailer is going to explode if you dump without your tank being full. :R
It doesn't neccessarily have to be full. 1/2 full will typically do the trick. You just want enough water to help the solids flow out. If you have a 40 gal tank and make a couple solids deposits with only a gallon or two of water to wash it down along with TP, you will have a situation very similar to leaving the valve open on a FHU site.
If you do a mix of long and short camping trips where most of the time, you get 20-40gallons in the tank, that will typically rinse the solids out even if you have the occasional short trip where only a few gallons makes it into the tank.
If you only do weekend camping and don't get a lot of water in the tank before draining, eventually (and it could be several years), you can get the same issue as leaving the drain open on a FHU site.
