C-Bears
May 06, 2015Explorer
Don't start looking for shadows to try to see if there is enough room to pull back in, that is just going to cause you to run someone off the road depending on where the sun is!
Seeing their two headlights should work. But if you have pulled for several hundred miles and are still uncomfortable when passing then maybe you should invest in a rear view camera system. Class A's generally have them because they can't see their towed vehicle, which makes sense. Generally fivers and TT's just figure out where their rear end is and don't really need the cameras.
About RV Newbies
4,032 PostsLatest Activity: May 30, 2015
