RRinNFla
Apr 27, 2016Explorer
With that size rig, you can put it in any site that is not "Tent Only". You are certainly entitled to the electric and water hookups. Unless you use the bathhouse for EVERYTHING toilet related, you will eventually have to connect to sewer, but that could be a dump station as you exit the campground.
Having said all of that, common courtesy would suggest that you leave the larger spaces for the larger rigs, unless here is absolutely nothing left. That is not usually the case. Usually the larger sites are reserved first and the smaller sites are often available at the last minute.
About RV Newbies
