Old-Biscuit
Mar 12, 2017Explorer III
MitchF150 wrote:
It's actually 12 years for a tank cert as far as I know...
I have had a tank valve leak if it was not closed 100 percent or opened 100 percent. If you only open the valve a couple of turns, it 'could' leak..
I'm not sure how a propane hose gets "clogged"?? I'm still on my original 15 year old hoses and regulator on my rig and they are just fine.
I've replaced several tanks over the years, but mine are only the little #20 or the standard BBQ tanks.. I do the exchange station swap when on of my tanks is getting too old.. I just swap for a new partially filled tank for $20 and I'm good for another 12 years and I just refill as needed.
Anyway, you can get those existing tanks recertified or spend a lot of $$ to buy new ones. Your choice.
Personally, I'd just switch to a pair of #20 ones and call it good.. Unless you need the capacity of those larger tanks for long trips at a time, there is no reason for the extra capacity, unless you just never check them between trips..
Anyway, good luck! We all do what works best for us, so this is just what I would do with the way I camp.
Mitch
DOT Certification Requirement for portable propane cylinders WAS 12 yrs after date of mfg as stamped on collar
That requirement was modified as of Jan 23, 2017
12 yr certification was changed to 10 yrs
5 yr 'Visual Inspection' still 5 yr
7 yr 'Proof Pressure Testing' increased to 10 yr
12 yr 'Volumetric Expansion Testing' lowered to 10 yrs
Info is slow to update....SOME Bulk Vendors have new regs.
Some mom/pop outfits still using 12yr
LPGA Magazine
BP News
DOT
About RV Newbies
