Old-Biscuit
Mar 12, 2017Explorer III
Boon Docker wrote:12th Man Fan wrote:
Did you have them laying down while you were Hauling them. if so that would also make them vent when they are full.
What would cause a tank to vent when it is laying on it's side?
Just laying them on their side would NOT cause relief valve to operate.
Problem is IF relief valve SHOULD open due to high pressure condition (heat) or failure then LIQUID propane (vs vapor) would be spewing out of relief valve.
Vapor dissipates quickly
Liquid Propane will 'burn' flesh (extreme cold burn)
Very damaging.
That is why Vertical portable propane CYLINDERS should be used/stored/transported in Vertical position
Horizontal Propane Cylinders have different design...can be used/stored/transported horizontally
Propane TANKS......well those are permanently mounted in MHs or set on legs/pads as in residential/commercial use
Tanks....ASME
Cylinders ---DOT
2 different vessels with different designs/requirements
About RV Newbies
