Diamond c wrote:
Actually your right, I don’t understand about bandwidth. I do understand that some people had rather be condescending than answer questions.
Most campgrounds that we have been to, either limit bandwidth (throttle it) or just don't have a lot of bandwidth to make streaming possible. A Wi-Fi Booster isn't going to help in that instance. Bandwidth is the maximum amount of data that is transmitted in a given amount of time. You can have great signal strength (maybe the campground's antenna is right next to your camp site) and you may have good download speeds (measured with a speed test web site/app), but if the campground limits how much data you can receive, there is no way to improve that.
At our seasonal campground, the owners don't throttle bandwidth, but they do monitor it. Our site was a good distance from the nearest Access Point, so I purchased a
Ubiquiti NanoStation that would grab the signal and send it directly to my router. Without the NanoStation, I would get 3 - 5 Mbps download speeds. With the NanoStation, I would get about 30 Mbps download speeds. 3-5 Mbps wouldn't make for a very good streaming experience, but 30 Mbps worked pretty well. We did not stream very often, maybe just a few movies/month.
I worked with the campground owners to make sure my NanoStation was connecting to a good access point that did not have a lot of bandwidth demand. It may have gotten a lot of connections because it was in a high traffic area, but it wasn't in a place where many other campers were using it for streaming or other bandwidth demanding activities, like gaming. That Access Point was about 250 yards from our site.
Our family of 4, average about 70 GB of data usage/month. When we are at home, we average about 1 TB of data usage/month.
As others have mentioned, for streaming, you'd be better off getting a 4G/5G hotspot device that offers lots of monthly data or if you are lucky an unlimited plan. You can also use your smartphone's hotspot feature, if your data plan offers lots of data. Some carriers will limit the amount of data you can consume through a smartphone's hotspot, so check with your carrier. Most smartphone hotspots allow multiple devices to connect to it.
-Michael
