- dodge_guyExplorer II
wa8yxm wrote:
dodge guy wrote:
Why not plug it into a Kill a Watt to see what it requires all around!
Now that I can answer.. The Kill-a-watt is a 15 amp device, though I have put 19 amps through one for about 1 minute (or less) there is an internal fuse that you are putting at risk, and replacements are 20 bucks (A new Kill-a-watt).
That said there is a rumor of a 30 amp version, but I've never seen it.
I was wondering about that after I posted, but figured someone would post a correction.
Good to know on the fuse! ;) - 1kennyOGExplorerI confirmed on paper it would handle it fine.
The 2 machines will be purchased on line, so I can't plug in what I don't have.
I figured maybe somebody here had something they were running that was around 20A that your Honda was handling with no issues.
thanks - wa8yxmExplorer III
That said there is a rumor of a 30 amp version, but I've never seen it. - ScottGNomadThe eu3000 Honda will handle that load just fine.
- 2oldmanExplorer IIWatts= volts x amps. That's how you confirm it...on paper.
- darsben1ExplorerThe manual states "The 8070 requires a 20A grounded circuit. Please note: GFI outlets may trip before the breaker setting.
SO given that figure we can extrapolate from the manual 115 volts x 20 Amps = 2300 watts max draw - dodge_guyExplorer IIWhy not plug it into a Kill a Watt to see what it requires all around!
- donn0128Explorer IIWhy not ask the mfg if that 19 amps is starting or running amps load? My guess its running as a 1000 watt heater alone is going to draw 10-12 amps.
- RedRocket204Explorer
1kennyOG wrote:
mytee machine
For that machine, I would seek out rental shops and have them fire up their generators to see which one can run that machine. Then rent the genny for a day and make sure it suits your needs.
About RV Newbies
4,032 PostsLatest Activity: Dec 23, 2025
