Has anyone changed their ww from 28 inches to a larger length? Mine do not while windshield high enough for me. Should the extra length be too much stress on motor ? And could u just change the length...
I went to 2 in longer blades for the same reason. The only issue I see is that when the window is dry like when I use the widow washer it will not come completely back to the original position. If it is wet like like when it is raining there is no problem.
