Bobbo wrote:
mowermech wrote:
For my first motorhome many years ago, I dumped 6 gallons of anti-freeze into the fresh water tank, then ran it through the system. I learned to NEVER do that again!
That is why they make the kit to have the pump suck the pink stuff out of the original bottles. You don't have to put it into the fresh water tank.
Works ok if your pump is easily accessable...our TT wasn't. Did it that way the first year and then I read the manual that said to dump it in the FW tank and go that way. Way easier for us.
But even that way, if you are worried about pink stuff in the lines, it will be there. You can drain it out of the FW tank.
