path1's avatar
path1
winterizing question Low point drains open or closed
Leave low points drains open or closed after blowing out water lines?
  • Leave open in case there is a small amount of moisture in the lines. I am assuming you are not using an antifreeze after blowing lines out. If using anti-freeze, of course low point drains would be closed.
