path1ExplorerDec 03, 2016winterizing question Low point drains open or closedLeave low points drains open or closed after blowing out water lines?
13 RepliesReplies sorted by NewestShow MoreDennis12ExplorerDec 03, 2016Don't forget traps.Dennis12ExplorerDec 03, 2016Don't forget trapscapndan77ExplorerDec 03, 2016Leave open in case there is a small amount of moisture in the lines. I am assuming you are not using an antifreeze after blowing lines out. If using anti-freeze, of course low point drains would be closed.
Related ContentHouse battery drainWinterizing QuestionBattery drain over winterWinterizing tips and trickswinterizing question
