tatest
Oct 12, 2014Explorer II
Handles on 90-degree ball T-valves are usually oriented to show which way the flow will be (my fresh tank drain being one counter example). For multiple valves, you can use that to work out a flow diagram for valve combinations.
That's assuming you can't find diagrams in the owners manual or posted in the utility bays (as Fleetwood preferred to do it).
There are so many different possible ways to connect freshwater plumbing that what works for one manufacturer and model may not apply to another. Best to make a diagram of what is actually there, valves and lines, physically.
About RV Newbies
