Rmack1
Jan 20, 2014Explorer
X-chock question
I read elsewhere that, according to the instructions, you are suppose to only attach the X-chocks after you unhitch. Why would that be? I've been setting everything before unhitching my TT. Somet...
2-MTnesters wrote:Rmack1 wrote:2-MTnesters wrote:
Maybe in case the trailer were to roll or shift a bit this would prevent it from being damaged. These are not to be used as wheel chocks they are to prevent movement fore and aft after proper chocking and set-up.
For one, if I have my one side up on stackers like I mentioned, regular wheel chocks won't work, as the wheels are not on the ground.
Even If the other side was very secure, the trailer could move a little, leaving the wheels hanging off one side of the stackers.
Maybe it's because I only have a 22' light weight TT, but I can't imagine the X-chock breaking. Looks pretty tough to me. It stays rock solid when I un-hitch, and keeps the wheels right in the middle of the stacker blocks like I left them.
Use whatever system that works for you but there are some people that will set up on a drastic slope and expect these things to keep a 15,000# rv from rolling down hill. The company says they are not meant to be installed until unhitched for this very reason. They aren't meant to chock the camper in this way. I would NOT want to depend on this chock alone to keep my 15,000#+ FW from rolling down a hill. If I have to crib up one side of my camper with the orange blocks I make sure there are enough extending beyond the tires for me to use my proper chocks at each of the 4 wheels, then after I unhook I install the X-chock. I never have the wheels resting on a single block wide. The way I've done it for several years and works for me. Tim
