Rmack1
Jan 20, 2014Explorer
X-chock question
I read elsewhere that, according to the instructions, you are suppose to only attach the X-chocks after you unhitch. Why would that be? I've been setting everything before unhitching my TT. Somet...
2-MTnesters wrote:
That is correct, if it takes 1 block high to achieve level then It may take 2 blocks to be able to extend beyond the tire, if 2 blocks high then may take 5 blocks (3 on bottom and 2 on top) etc. I have never had the blocks slide on me, the fact that the chocks on the opposite side are directly on the ground also assist in preventing sliding as well. I also carry 3 sets of the Lynx Levelers (each set containing 10 blocks) with me to ensure I have plenty to crib up safely and ensure stability.
