HVFDFIREFIGHTER wrote:
Planning on power A few 100 watt cfl bulbs so only 23 watts each total 115 watts, maybe a fan 200 watts I am guessing, led tv 50'watt DVD player 50 watt shuffle pressure pump 103 watts, radio50 watts,
total 500 watts or so.
Maybe a coffee maker, toaster, or microwave -all about 1000 watts each but not all on at once.HVFDFIREFIGHTER wrote:
OK and I think you are better with 12v lighting and run the big stuff like coffee, toaster, microwave direct off the Yamaha 2000. Some of the electronic controls may not even work properly on MSW. Batteries are slow to charge so 10 minutes of use can be 30 to 60 minutes of charging.
Going with the Energizer 1500C/3000S watt inverter (I like this one because it has the modified sine wave and a digital read out on the top of the unit so I can mount it to the wall and be able to read it).
For charging small items like a phone or laptop I recommend 150 to 300 watt sine wave inverter.HVFDFIREFIGHTER wrote:
These will serve you well.
I am pretty sure I am going with 2 Duracell 6 volt 215 amp hour batteries from Sam's Club connected in series to make 1 12 volt at 215 amp hour.HVFDFIREFIGHTER wrote:
Yes but those chargers are too slow.
Can I charge two 6 volt batteries connected in series with a 12 volt charger?
Far better to invest in a 3-stage converter such as Progressive dynamics 9260.
http://www.bestconverter.com/9200-Series-Deck-Mount_c_84.html- westendExplorer
willald wrote:
Do you have a dehumidifier?pianotuna wrote:
This is bad advice.willald wrote:
You can also use 'drinking' water for this, that also is sold in grocery stores by the gallon.
Perhaps, but we've been doing it for years, have never had a problem, yet. :)
I agree, though, that distilled water is better if you can find it. Sometimes you cannot, though, and drinking water will work, and is better than letting a battery cell run dry.
Will - willaldExplorer II
Will - CapnCampnExplorer III
Yes, this is what most people do.
Now you get to think about which charger is best for you. :h
Balance gen time with cost of charger vs ease of use vs... ;) - pianotunaNomad IIIThis is bad advice.
willald wrote:
You can also use 'drinking' water for this, that also is sold in grocery stores by the gallon. - HVFDFIREFIGHTERExplorerCan I charge two 6 volt batteries connected in series with a 12 volt charger?
- HVFDFIREFIGHTERExplorerI have an old hood vent from an oven that I got from someone. Not going to actually plug the fan and light in but was thinking of using this overtop of the batteries and venting to the outside.
- westendExplorer
The 6 volt Golf Car batteries would need to be in a vented area when charging and discharging?
Yes, or a vented battery box. I built a vented box but it is easier to buy a HDPE box for $50 and fashion the vent to the exterior.
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Jan 17, 2025
