colliehauler
Apr 16, 2015Explorer III
HVFDFIREFIGHTER wrote:Correct but 2 six volt batteries will not power a heavy load through a inverter. You are better off running the generator and skip the inverter. Your camper should have a charger built in so all you have to do is plug in to the generator and it will charge the batteries although it will take awhile. You might want to look into solar to keep the batteries maintained while your not there and use the generator for heavy loads.
MY BAD! How about this?
To connect charger to battery bank and battery bank to inverter
2 6 volt batteries in series @215 amph each = 12volts at 215 amp hour
Bat A- to Bat B+
CHARGER+ to Bat A+
CHARGER- to BAT B-
Inverter+ to BAT A+
Inverter- to BAT B-
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Apr 15, 2020
