dcmac214's avatar
dcmac214
? De-winterizing Question
Question: How long does it take in flushing the lines out for the bubbly effect of the antifreeze to get flushed out?
RV was in the shop last fall so we had a pro winterize it at the same time. Years past we've just blown out the water lines and dumped a few bottles of antifreeze in the traps & holding tanks. This is first time the water lines were 'antifreezed'.
I've run three full tanks of fresh water thru the water lines and it looks clear enough but still comes out bubbly, way more bubbly than what the aerators make it. Not as bad as when I started but still...
  • Just because you paid a shop to winterize your RV, doesn't mean it was done by a pro.
    Personally, I would keep flushing the lines and FW tank until you get everything out. Then next winter go back to blowing out the lines and using pink stuff in the traps.
    I've been doing that for years.
  • You shouldn't taste it much after a few gallons, unless some dumkoff poured water into your fresh water tank and ran the pump, even worse if you got some antifreeze in your hot water tank too.
    If you can taste it still... some places that can be missed when you de-winterize it... the water fill for direct outside connection. If you are filling your tank and running the pump, drain off the pressure completely, press the check valve on the side of the rig where you connect the hose, then have someone start the pump. Pink?
Looking for advice before your next adventure? Look no further.25,172 PostsLatest Activity: Oct 23, 2025
