MitchF150
Apr 27, 2013Nomad
While I don't have an EQ hitch setup, it's just a standard EAZ Lift WD setup, but the hitch head is rated for 14k lbs and I'm running #1000 bars for a #5000 GVWR TT...
What are your bar ratings for each hitch head rating? My guess is the 10k probably has #1000 or #1200 bars and the 6k probably has #600 or #800 bars..
Considering how the EQ works compared to a standard WD setup, there could be some truth to that statement you heard... Then again, you can adjust the tension on an EQ just as I can on my EAZ Lift, so there you go... :)
Mitch
Mitch
Looking for advice before your next adventure? Look no further.25,179 PostsLatest Activity: Jan 16, 2026
