Desert_Captain
Apr 29, 2013Explorer III
Ron Gratz wrote:Desert Captain wrote:What does "at the maximum of" mean as applied to WD bars?
It just makes no sense whatsoever to be near or at the maximum of anything.---
With the OP's rig, a TW of 625# would cause a load of about 240# to be removed from the TV's steer axle.
To restore the front axle to the unhitched value would require a load of about 480# to be applied to each WD bar.
Are you going to tell us that a load of 480# applied to a WD bar rated for 600# would put the bar "near or at the maximum"?
If the OP ever loads to near his GVWR he will need to move more than 600#. So now which bar does a better job, one capable of 600 or one rated at 1,000#? IMHO: It is nice to have the reserve capacity availableDesert Captain wrote:One possible advantage is that the difference in ride, with more flexible bars versus less flexible bars, might not be insignificant.
---The difference in ride and handling is also insignificant. What possible advantage is there to going with the lighter/weaker WDH?---
The less flexible bars can transfer more road shock from TT to TV.
Another possible advantage is that the difference in handling, with more flexible bars versus less flexible bars, might not be insignificant.
The less flexible bars will cause greater variations in load transfer when the TV's rear tires go through a dip or over a bump.
Another possible advantage is that the difference in fatigue loading on the TV's receiver and the TT's A-frame and body might not be insignificant.
The less flexible bars likely will cause larger dynamic forces and moments to be transmitted between TV and TT and vice versa.
All three of your "possible advantages" are about more flex and come with "might nots". I tow a 4600/5000# TT with the 1,000# bars and the ride and control are excellent. I'm glad there is less metal "flexing" on my rig. With the lighter bars it might ride a little better but then again, it might not.Desert Captain wrote:Which hitch is the biggest seller proves nothing. If they do sell more of the 1000/10000# model, do you think it might be due to the fact that they do not sell an 800/8000#.? And, if you closely followed WDH selection discussions on this Forum, you would know that Equal-i-zer loses sales to Reese because the former does not offer an 800# hitch and the latter does.
---Check with Progress Mfg and ask how many of each unit they sell. Want to wager that the 1,000/10,000# model is the overwhelming sales leader?
Sales prove a lot as it accurately reflects what product is meeting the needs of most consumers.Desert Captain wrote:Does that apply to someone who tows with a truck which "comes in at 6924# against a GVWR of 7050#"?
Depends, is the TT that truck is towing 4,000# under the TV's rated towing capacity and 3,500# under the GCWR? You really need to look at all three to see how hard the TV is working. Also that TT's GVWR can be adjusted easily enough by loading more into the TT without significantly changing the relevant numbers. The WDH is where the TT and TV come together and redistribute the loads and should be the last place you want to skimp. As I recall that's what we are talking about. :C
Ron
Looking for advice before your next adventure? Look no further.25,179 PostsLatest Activity: Jan 13, 2026
