FL_JasonR's avatar
FL_JasonR
1/2 ton truck towing question
I am looking for a toy hauler to put a golf cart in. I’ve seen a few but they will be about 10,000 pounds after everything is loaded. Current tow capacity on the truck is 9300lbs. With GVWR @ 7,000lbs. I found a shop that will add an extra leaf to the rear end (.47in steel leaf, was told that would add roughly 600lbs each side) and install HD sway bars. Do you think this will be enough to increase my GVWR?
Looking for advice before your next adventure? Look no further.25,177 PostsLatest Activity: Nov 17, 2025
