- jarata1Explorer
TomG2 wrote:
bob213 wrote:
I'm just going by what the rep told me. Like I said, it's not a debate between 6v and 12v, deep cycle or starting. Why do you people have to turn every post into a pissing contest?
Because the forums are populated by a bunch of lonely old men who think they know everything about everything. Don't believe me? Mention Diesel, Walmart, Harbor Freight, Half ton, Hitch, or Generator in any of your posts. If you want to find out what they think is best, just check their profile for what they own.
+1 - jarata1Explorer
Not worth it - pnicholsExplorer III just ignore the 6V golf cart battery crowd's fanboy comments, too. 12 volt Group 24/27/29/31 batteries are the only ones that fit where batteries belong in our RV.
That being given and since I want to use true deep cycle batteries, I have to budget for the extra cost of either true deep cycle 12V wet cell batteries or true deep cycle 12V AGM dry batteries.
Trojan and a few other manufacturers offer true deep cycle 12V wet cell batteries, and several manufacturers offer true deep cycle 12V AGM dry batteries.
However no matter what type or what manufacturer of (new) true deep cycle 12V battery you buy - they will always cost more than the easily available and inexpensive common 6V golf cart type wet cell true deep cycle batteries or the common 12V marine non-true-deep-cycle batteries that are found everywhere.
It's as simple (or complicated) as the above ... unless you opt for the ultimate and can pickup used 6V or 12V true deep cycle AGM dry batteries that are both cheap and have plenty of years left.
I saved up our money and installed a couple of new Group 31 true deep cycle 12V AGM dry battteries that hopefully will give me at least 6-8 years of hassle-free service. - bob213ExplorerTomG2...Well said.
- TomG2Explorer
Because the forums are populated by a bunch of lonely old men who think they know everything about everything. Don't believe me? Mention Diesel, Walmart, Harbor Freight, Half ton, Hitch, or Generator in any of your posts. If you want to find out what they think is best, just check their profile for what they own. - bob213ExplorerI'm just going by what the rep told me. Like I said, it's not a debate between 6v and 12v, deep cycle or starting. Why do you people have to turn every post into a pissing contest?
- theoldwizard1Explorer II
bob213 wrote:
theoldwizard1...I believe you are incorrect about the Duracell 24 DCC battery being a dual purpose battery. The 24DC might be what you are thinking of. According to the rep I spoke with at East Penn(the mfg) it is a deep cell, not intended as a starting battery.
If it is NOT a cranking battery why do they advertise both Cold Cranking Amps (CCA: 500) and Marine Cranking Amps (MCA: 615) ? - I agree with the theoldwizard1.
However if you just need something while you roll between pedestals it will serve you well. - bob213Explorerwasted effort
- theoldwizard1Explorer IIThe Duracell 24DCC is not a "true" deep discharge battery. It is a dual purpose battery. Good, but not as good as a "true" deep discharge battery.
It is hard to find 12V deep discharge flooded or AGM batteries without special ordering them. And they are expensive. This is why so many people are using two 6V golf cart batteries, if you have the space. These ARE "true" deep discharge battery and they typically in stock and are very reasonable priced at either Sam's Club or Costco.
Looking for advice before your next adventure? Look no further.25,195 PostsLatest Activity: May 02, 2026
