04fxsts's avatar
04fxsts
12 volt transfer pump
We decided to replace the MH with a smaller TT, we are done traveling so it is a better fit. We own our own camping spot on a local river so it will sit there most of the summer unless the river floods then it will come home. Got a portable waste tank I can bring home and dump in our septic system. I will need to fill the fresh water so I am looking for a 12 volt pump for that. Anyone have a setup that works well for them? Thanks in advance, Jim.
  • Just wanted to check back, good idea getting a pump that will replace the one in the TT. Also like the idea of being able to suck water with the existing pump. will have to get better acquainted with the pluming. Jim.
  • ktmrfs wrote:
    Works great and game me a reason to replace the noisy OEM TT water pump. Put a higher quality, quieter pump as the main pump and used the old OEM as the one in the pass through.
    What pump did you buy to replace it?
  • I bought a 12 volt pump from Northern tools which hooks up to the battery. It works well since my water inlet is by the front of the trailer.I fill up a 6 gallon portable tank and then pump the water from there into the water fill on the camper.It works well.
Looking for advice before your next adventure? Look no further.25,102 PostsLatest Activity: Jan 17, 2025
