Scott_M's avatar
Scott_M
12 Volt/120 Volt Portable Air Compressor
For years, I have carried one of the those cheap and small Kobalt 12 Volt/120 Volt air compressors. Lately, it has been overheating the thermal protection switch trips so I have to wait for it to cool down between uses. Can anyone recommend a good quality compact air compressor that can air up 80 PSI tires? I would like a dual supply power like the Kobalt has and a compact size like the Kobalt. I do have the generator to supply 120 volts if needed, but I like being able to use the battery in some situations. May be a 120 to 150 PSI max range? Thanks!
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 19, 2026
