campermama's avatar
campermama
Explorer II
Apr 02, 2020
12v outlet question
My new trailer doesn't have a 12v outlet near the tv. The tv is near the back of the trailer in a slide. I can't figure out how to run the wires from the battery back to the tv area to add a 12v outlet.
I'm wanting to add this outlet because I mostly boondock and I have a 600w inverter that plugs into a 12v socket and the tv plugs into the inverter so I can watch some tv.
So I had another idea....what if I add another outlet up front close to the batteries, I can do this easily, then plug In the inverter there and use an extension cord over to the tv (tv plugs into extension cord). Will this work?
Anybody have any other ideas to do this easily?
TIA!
  • “Also, what gauge wire should I use, and what size fuse?“
    Wire gauge can’t be determined until you confirm the distance and if the wire will carry 12 or 110 volts.
  • Fisherman wrote:
    That works, keep the inverter as close to the battery as you can.
    Definitely. 600 watts is 50 amps at 12 volts but only 5 amps at 120 volts.
  • I know you replied with questions but going to skip those for now. Smarter guys than me are going to read your replies.
    Pictures of the trailer would help to get clever with inverter placement. Especially where your circuit breakers are and also a panel with all the switches.
    Dont need a close up. Further away is better. The goal is to find the best spot to get 12v power, instead of running wires from the batteries directly. You already have a ton of 12v inside the trailer. To run a TV you wont need much so you can borrow power from something like a powered awning. Fuel pump. Rear exterior lights you never use.
  • Do you have space for the inverter close to the fuse/breaker panel?
    If yes consider mounting the inverter right there. Get 12v power from the main battery feed. Use a small transfer switch to power up the single branch circuit that goes to the tv.
    https://www.donrowe.com/KISAE-TS15A-Automatic-Transfer-Switch $50
    If by chance the fridge is also on that circuit you will need to set it to propane only. If the converter happens to be on that circuit will need to find the best way to de-power it.
  • wopachop wrote:
    Do you bounce the 600w inverter between vehicles? Instead of going through the process of adding a cigarette lighter, the inverter would perform better if hardwired.
    No, only use it in the trailer.
    So you mean wire it right to the batteries? I would have to add some wire to it. I have two batteries, would you wire it to one battery? Or both (can you do that?)
  • Do you bounce the 600w inverter between vehicles? Instead of going through the process of adding a cigarette lighter, the inverter would perform better if hardwired.
Looking for advice before your next adventure? Look no further.25,116 PostsLatest Activity: Mar 09, 2025
