bigorange
Jun 12, 2020Explorer
brianosaur wrote:Lynnmor wrote:
Can you tap into wiring to a lighting circuit? Most are protected by a 15 amp fuse, so use #14 wire.
Okay now that I am digging around, ^this^ got me thinking with an 'ahh ha'!
The Furion radio/dvd player is in the wall console under the TV and right where I want the socket.
Can I just tap into that 12v line with a wire run of less than two feet? Its a 15a fuse.
I guess I should check the radio manual to see how many amps it draws first?
It doesn’t necessarily mean it’s the proper way to do it or rated properly, but this is exactly what I did in our old trailer...tapped into the radio power wire to install USB jack nearby. New trailer has a ton of USB jacks...I guess that’s a premium addition to trailers now.
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Apr 15, 2020
