jadatis
May 02, 2017Explorer
Asuming you have 4 tires and 2 axles, you need at least 8000/4= 2000 lbs maximum load a tire.
Found with google LT 195R15 Loadindex 106/104 wich is maximum load a tire single 2050 lbs , and Dual 1984 , so for dual load axle ( 1 axles with 4 tires on it) to less , and for tandemaxle so 2 axels and 4 tires total , eanaugh to law but a bit poor .
But if you never load it fully , it would be enaugh.
When you load it to the max , minimum of 10% reserve would be nice for unequall load R/L , little overloading.
So that would mean a loadindex of 108 would be needed with 2205 lbs maximum load.
These are the things you have to take in to account when searching for tires.
Looking for advice before your next adventure? Look no further.25,211 PostsLatest Activity: Aug 31, 2026
