You don't say what you have which may or may not make a difference. I installed recessed heaters in our TT and can add some comments.
It depends somewhat on how well your camper is insulated. Many are not plus they can leak like a sieve. We had lots of holes in the floor in ours, including one about 8x8" and I sealed them all up with foam. Having run lots of various wiring through the ceiling, I've found the insulation workmanship in the ceiling cavity to be terrible and in some locations there isn't any.
Your floor will feel uncomfortably cold in colder temps. You may want to wear thicker socks. If you have an enclosed underbelly, tanks and piping won't get any heat so if the temps. will drop below 32, something could freeze up.
You will need to maintain the required safety clearances on all sides of the heater. Can be a challenge to find a suitable spot. I installed a semi-recessed heater on the ceiling in a previous TT because there was no other place - worked fine.
In colder weather, you need to ventilate the interior to remove moisture laden air. If you don't, you can end with issues like mold, rot and delamination. An electric dehumidifier may be needed if you plan to use your camper often in cold weather. Cracking vents and windows and/or running a fan means you lose some heat. Don't seal everything up with in an effort to retain heat.
I'd get a heater with a squirrel cage blower instead of a propeller fan because they're much quieter. These heaters aren't cheap and don't get the cheapest one you can find. You don't need to share the circuit for the AC unit, Just get tandem breaker and run a new circuit back to the panel. You'll never run the heaters and AC together (and if you did, you'll just trip a breaker). Wiring can be run 100% concealed via ceilings, interior walls, cabinetry, under shower, etc. It will take longer to get the interior up to a comfortable temp. when you get to a new site but can always use the furnace at first. I'm an EE and have never run into a heater that doesn't put out it's rated wattage and they must meet a UL standard that specifies output requirement. Note that ratings are at
120 volts and heat output varies as the square of the voltage so try and have good voltage. If you can, install a wall mounted t'stat because they function better compared to an integral built-in one on a heater. I'd suggest two smaller wattage heaters in different areas for more even heating.
We have a 29' TT and I installed two recessed heater like the OP shows plus a 1KW recessed kickspace heater below the stove and have it set up at 2,000 watts total. One heater is above the bed, one is in the bathroom and one is at the rear of the TT in the kitchen. Provides even and comfy heating from front to rear. I used
King Pic-a-watt "PAW" heaters which have adjustable tap settings from 250 to 1500 watts in 250 watt increments. I made my own demand controller using a current sensing relay that automatically shuts off the heaters when something gets plugged in that exceeds 30 amps total into the TT. I used wall mounted low voltage thermostats for better control. 2,000 watts isn't quite enough below 40F as the heaters run continuously, esp. the one in the kitchen as it covers a larger area. I did this a few seasons ago and haven't had to use the furnace since - not sure if it still works, lol. And yes, these heaters put out their rated wattage.
