Old-Biscuit wrote:
You need a 5vr with a 12,000# max GVWR (or less depending on diff. gearing) because your 2500 will run out of actual payload capacity, RAWR and Rear Tire MAX Load Ratings and trucks GVWR above 12,000# gross trailer weight.
You can check your model tow rating HERE
You want your hitch to be rating for more than trailers GVWR.
But you really need to match 5vr with your trucks ratings
Thanks for the hot link to the dodge web site. As it turns out my truck can handle less payload than the 15k hitch (as you noted). So I will need to use the truck payload capacity to determine the correct weight for the trailer. Jim2007
