melloftus's avatar
melloftus
1st time boondocking and could not get our AC to work
We did our 1st time boondocking trip this last weekend with our 2008 fleetwood mallard and sadly we could not get our A/C to work. My husband is now convinced we need a new generator where as I think maybe there may be some other options. We have a 13,500 BTU A/C. and a Champion 3400 starting watts/3100 running watts. We tested the unit at home after doing the generator break in, on the 1st attempt we overloaded the generator, I did some reading and took a different approach, 1st just turning on the fan for about 15 min then switching over to the AC on the thermostat. This seemed to do the trick and I was confident we had nailed it..not so much. I am hoping you good folks could maybe give some guidance maybe some suggestions. We were able to get it to come on once this weekend and it seemed that when the compressor kicked in this was when the overload would happen.or if it didnt overload it sure dogged out..
If I started out with the fan on only sometimes when I kicked it to AC the generator would overload,fan would stop, If I could get the system to take the change over to the A/C with the thermostat set higher if I lowered the thermostat most times it overloaded the generator.
Here is where I think we may have made some mistakes..
1) we did have our battery disconnect switched to ON- do you think it was directing power to try to charge the deep cells- I was under the impression this should be set to ON even when connected to shore power/gen power. Our the deep cells were reading full(ish) hard to tell as our meter only goes in quarter settings not % but I just watched a youtube stating this may have pulled power from the generator lowering the available wattage??
2) I was running fridge on 100% propane so I don't think that would have pulled a draw
3) we were using an 30 amp extension cord direct from our TT cord- when we tried at home we were connected direct into the TT/Gen and still got a overload
4) we were at 5,000 plus feet... I know this lowers a generators output(i am guessing about 15%) .. however we are at sea level at home and still had overload issues.
I am thinking we may need to install some sort of Hard Start Capacitor..
Thoughts??
Looking for advice before your next adventure? Look no further.25,186 PostsLatest Activity: Mar 11, 2026
