Hornnumb2's avatar
Hornnumb2
2 1/2 to 2 adapter
Just moved up to a 2500 from 1/2 ton. The hitch is 2 1/2 and I bought the adapter sleeve to go to 2in. The sleeve says to not use with weight distribution. So what are my option for my E2. Thanks Michael
  • Try it out as is, then decide. Only you can make that call.
  • Ok the 2 1/2in shank is almost $200 and I am using a E2. Should I go ahead and spend some more and upgrade to new hitch or just spend another $200 on this one. I just upgraded to heavier bars about 4 months ago. This hitch is getting expensive.
  • I got a 2-1/2" shank and got rid of the excess play. I've also read about bent pins from using the adapter. You see, that 1/4" space around the shank might as well be air, the adapter is just a locator.
  • Some times the adaptor is not long enough, and with the adaptor, you do have a little more play/slop, not good for WD hitch.
  • Tvov's avatar
    Tvov
    Explorer II
    MHWASH wrote:
    I've towed lots with my factory GM adapter and Equilizer WD hitch. Roughly 10,000 TH. No issues or any apparent wear on the sleeve.
    Maybe a "factory" adapter is okay to use?
  • Is this true with all adapters? I've been using adapters for years and no problems. Just wondering if this was brand specific.
  • I've towed lots with my factory GM adapter and Equilizer WD hitch. Roughly 10,000 TH. No issues or any apparent wear on the sleeve.
Looking for advice before your next adventure? Look no further.25,186 PostsLatest Activity: Mar 13, 2026
