fla-gypsy
May 02, 2014Explorer
Doing a little investigative work I see you own a Wildcat 5th wheel 32+ ft long. The GVWR on those is 11,999. I also see you commented that the tires had 70 psi in them which indicates you probably have 15" D rated tires on them or you have underinflated your 16" E rated tires. Either situation would be a serious concern. 15" D tires on a trailer that size would be operating very near their weight limit and 16" E rated tires inflated to 70 psi would be considerably underinflated for Maxxis tires. How much does the 5th wheel actually weigh and which size tires are you using?
Looking for advice before your next adventure? Look no further.25,207 PostsLatest Activity: Aug 26, 2026
