nomad297
May 02, 2014Explorer
Try a basic check for axle alignment. Measure from center to center of the wheels on each side of the trailer. If the two sides don't match, you have an alignment problem. There are several other measurements that need to be checked for proper alignment, but this is an easy one that you can do. I had a similar experience to yours. I found my axles were not aligned -- there was over an inch difference from side to side.
Bruce
Bruce
Looking for advice before your next adventure? Look no further.25,207 PostsLatest Activity: Aug 26, 2026
