love4god's avatar
love4god
2 Blowouts, different tires, different axles, 1 hour apart
I am driving on the 95 North today through South Carolina. We got a honking horn next to us, someone telling us our tire was flat. I pulled over and we were pretty flat but not blown out. I pulled over and changed the tire to my spare (full size) tire.
About an hour later we're driving on same road, the OTHER axle OTHER side of the trailer we got a blowout?!?!
These are nice MAXXUS tires, less than a year old. Tires have tons of tread and seem like they're in great shape. I figure I got a nail or something in the one and slow leaked (all though I couldn't find anything).
Any idea what could cause 2 tires on different axles on different sides of the trailer both blowout an hour apart? I saw lots of rubber on the road but this was a long distance apart and it didn't happen in one spot where there could have been road hazards, it was 60 miles apart.
I was driving about 60, I had just checked air pressure after fixing first flat so other tires were at 70psi. I haven't added any weight, if anything I just got rid of a few things that would have brought me down a hundred pounds or so.
It's baffling me!
  • How old is the RV? How much weight is on the tires? What are the tires rated at?
    You did say that the tires are about a year old, is that by the date code on the tire? Or just that you had them installed a year ago?
    Do you know how to read the date codes? It will be a 4 digit code, such as 4507 meaning it was manufactured on the 45th week of 07 and is now nearly 7 years old, and to old to be on the road. Hopefully your tires will be something like 2212 or 2213 if they are only about a year old, and where somewhat new when installed.
    Sears was on camera when a news crew purchased a "New" tire with a date code 11 years old from one of their tire stores. The installer said that it would work great as a spare tire. Seems that the tire shop rarely rotated the display tires away from the window to the stockroom.
    Hopefully you where able to get back on the road soon. When I buy a trailer, I will change the ST tires to the more durable LT tires, and make sure they are not made in China.
    I might even change from 16" rims and tires to 17.5 or 18 or 19.5" rims that seem to be rated at a lot more weight. Some RV manufactures only put on tires barely rated at the axle rating, and then "Expect" them to last a long time.
    For instance a trailer with a 16,500 pound GVWR with a pair of 7,000 pound axles and a hitch weight rating around 2,500 pounds. The tires and rims are rated at 3,550 pounds each. That is just "barely enough" weight rating. What about turning and curves? What happens if you drop one tire off the pavement while getting on the freeway or while exiting a gas station? then the other tire takes much more weight for a few seconds.
    I would rather have two axles rated at 8,000 pounds with rims and tires rated at 4,400 pounds each, than ones barely up to the task at hand. Sure the axles should not weigh more than 6,600 pounds on a typical trip, and the 3,550 pound tires should not have more than 3,200 pounds on them - except while the RV is leaning into a curve. But tires get more than the rated load on each curve, that is why I wanted something much stronger.
    Good luck with your tires.
    Fred.
  • What was the condition of the roads. Were they rough? Lots of pot holes?
  • Any travel on unusually rough roads recently? How about unusually tight turns while manuvering into a site? (Rough side scuffing). I camped in a state park last night that had 5 miles of rough pot holed roads and rediculously tight manuvering into sites. Wouldn't have been surprised to have had damage to a tire or two.
  • Could axles that haven't been greased in a long while possibly cause this?
Looking for advice before your next adventure? Look no further.25,179 PostsLatest Activity: Jan 15, 2026
