dodge_guy
Nov 06, 2017Explorer II
To get the pink into the fresh water inlet. run the pink through the entire system. then relieve pressure by turning off the pump and opening a faucet. go out side and push in gently on the inlet spring and let the water trickle out till its pink. don't do it under pressure or you could damage the valve.
pink stuff is the only way to know you have 100% of the water out!
Looking for advice before your next adventure? Look no further.25,192 PostsLatest Activity: Apr 15, 2026
