jerem0621
Apr 04, 2013Explorer II
redavis wrote:jerem0621 wrote:
IMHO.. The 2 1/2 is no longer required.
You can get forged shanks that are strong enough in 2 inch receivers to pull pretty much anything.
The strongest receiver I can find for a superduty like ours is made by Curt
Its rated for max trailer weight of 20,000 lbs and a max tongue weight of 2,700 lbs WITH OR WITHOUT Weight distribution.
Very substantial for a 2 inch receiver.
Here is a Link
This is way you never have to worry about receiver strength ever again. And its only $321.40 from Etrailer..
Thanks!
Jeremiah
Unless I'm missing something, the link you provided is to a 2 1/2" receiver, not a 2".
Randy
Good catch, that is what I get for having multiple tabs open doing research.
Here is the correct Link
This is a 2 inch receiver rated at 17,000lbs GTW and 2550 LBS tongue weight either in WC or WD mode.... still quite a substantial hitch, but as John pointed out, the shank is the limiting factor here.
Thanks!
Looking for advice before your next adventure? Look no further.25,210 PostsLatest Activity: Aug 29, 2026
