FireRob's avatar
FireRob
2 1/2" Receiver Hitch and 2" Equal-I-Zer Shank
Hello again everyone,
I just found out Equal-i-zer makes a 2 1/2" shank to go into the receiver hitch. My dealer installed a 2" shank and used the reducer that came with my truck. Is this acceptable or should I replace the shank with one intended for my Class V 2 1/2" receiver hitch?
Details to avoid other questions that some might find relevant:
This is a new trailer I picked up 9-26-14 and the hitch was part of the package deal when I bought the trailer.
Don't know any of the weights/limits of the trailer or hitch (but can look up if you really think it's necessary)
OK trailer numbers according to dealer Spec's
Hitch Weight 1,071 lbs
Dry Weight 7,875 lbs
Gross Weight 9,671 lbs
Cargo weight 1,796 lbs
I still don't know what to tell you on receiver numbers other then its a Class V two and one half inch receiver on a 3/4 Ton Ram Diesel.
Should I go back to the dealer and ask for the correct shank so the reducer is not needed or just not worry about it and tow till my little heart is content?
