afinepoint's avatar
afinepoint
2" vs 2 1/2" receiver hitch. How to choose?
I have to change out my Draw-tite receiver. It has a 14000/1400 WD rating. The TH tongue is 1280 lbs.
I've been on the phone with three hitch suppliers, a hitch installer and various Internet sources. I getting worn down with information.
I've received advice on hitches from 1500 to 2550 TW rating and 15000 to 20000 tow ratings. 2 and 2 1/2" sizes. All recommended for my application. They can't all be the right hitch. The 2550 seems way too high and the 1500 I know to be too low.
The trailer has a 63 gallon fresh water tank and 34/34 grey/black. The weight in the cargo area will be negligible. It might take 100 lbs off of the tongue.
Regarding the size of the receiver opening should one look first at the WD set up for the trailer and then choose accordingly? My plan is to put a Reese DC on the trailer which would require the 2 1/2" But this could change.
Why is that some 2" receiver hitch ratings exceed the 2 1/2" ones? One person said the max rated ball he could get was 18,000/1800 lbs for the 2 1/2. So . . . how do you tow greater?
Why buy a hitch with a capacity that exceeds that of the vehicle as the 2550 lbs would?
2" or 2 1/2"? 2 1/2" or 2"?
I suppose with my decision to get the Reese DC the choice is made for my but if one hasn't picked out the trailer hitch how does one decide?
Reg
  • so what happens if you get a larger TT and it calls for more weight in the hitch dept. go out and buy another set up. get the big one and get it over with.
  • If you get the 2.5 you can always bushing it to 2. If you get the big one you never have to worry about it being too light. Just my opinion but you know what they say about opinions.
