06Fargo wrote:
What exactly would be the negative effects of bio diesel blended fuel in California's climate?
The problems are largely with switching from B20 to B5 to straight diesel from tank to tank of fuel. Fewest problems with using B20 only and only in the summer months in areas where the temperatures stay above freezing throughout the day and night. If you live in a temperate area but drive up to the mountains in the winter then B20 can cause problems with newer trucks and is a very big problem with pre 2011 trucks that don't have the special fuel warmer that was added to cope with biodiesel.
The current generation of diesel engines use a high pressure common rail system that is operating at up to 41,000 PSI and is a lot more sensitive to problems with the fuel supply than older engines. Effective fuel filtration is critical and injector repairs are more expensive than a complete engine rebuild of a gas engine. There is no benefit to consumers in burning B20 biodiesel, only to the giant ag corporations and the Congressmen in their pockets.
