Nathanbates114's avatar
Mar 10, 2023
2002 3/4 Ton Heavy Duty Diesel Chevy 2500
Hey everyone,
My wife and I bought our first travel trailer 2 years ago and we have been living in it full time and love it. We just had our first baby boy and the trailer we have now is starting to get cramped and we're looking to upgrade to a fifth wheel or larger travel trailer. My father in law said we can borrow his truck to tow and says it's a "2002 3/4 Ton Heavy Duty Diesel 4x4 Chevy (pretty sure it's a 2500) He says it can tow around 16,000-18,000 pounds but I'm having a hard time finding the towing capacity online. Can someone help me find the towing capacity?Or if you have the same truck, I would really appreciate it if you could give me the specs for this truck. Thanks in advance!
-Nate
  • ^^Good info from JIMNLIN
    While the truck may be capable of towing a heavier trailer, it can only carry the weight of the axle wt ratings. A FW trailer will have a pin wt of 20%, or slightly more. All this pin wt sits over the rear axle.
    Jerry
  • it's a "2002 3/4 Ton Heavy Duty Diesel 4x4 Chevy
    3/4 ton truck from that era had around 9000 gvwrs and 6084 rawr.
    My 2500 Dodge/Cummins 305/555HO NV5600 tranny 3.73 gears has a 13400 lb tow rating. A '02 2500 GM diesel will have around the same tow rating.
    A 13000 lb 5th wheel trailer can have around 2600-2800 lb hitch weight which will go over the truck 6084 lb rated rear axle. The weight of the hitch and other gear in the bed adds up also so your looking at approx 3000 lbs at the most for your 2500 truck.
    3/4 ton trucks that era rear axle weighs in the 2700-2900 lb range. You have the truck so drop by a CAT scale and find the trucks front and rear axle weights with attention to the trucks rear axle numbers.....then do the math. You don't want to exceed GM 2500 6084 rawr numbers (tire/wheel/rear spring pack).
    I would stick with a 12k-13k gvwr (9000 lb dry weight) 5th wheel trailer as a max size.
  • Your father in law is so wrong on this I don't know where to start.
Looking for advice before your next adventure? Look no further.25,108 PostsLatest Activity: Feb 05, 2025
