bocanut50's avatar
bocanut50
2012 and older Ford Escape's
This is a FYI if you own a Ford Escape. 2012 and older.
We had a 2011 Escape, Automatic. This applies to 2012 and older. 2013 and newer ARE NOT TOWABLE. They have a different transmission.
Our 5 months of hell.
We bought the Escape new in 2011. First trip out we lost the first transmission in NC at 1100 miles on the vehicle. All 4 down protocols were followed. Ford replaced the transmission within one week and provided a rental car. The repair dealership also provided also provided a Service Bulletin that the Selling dealership didn't,' even though they new ahead of time we were towing the car 4 down. That's when we found out about the transmission level. All other shifting rules and speeds were followed.
This year, also in NC, in July, the same thing happened. This time it took Ford 5 days to tell us they wouldn't have a transmission until Sept. We made a decision to Trailer the car back to PA and have it fixed here. So we waited until Sept, only to be told by FORD that it would be late in DEC. we MIGHT have a transmission. In late Oct, We told them that was unacceptable and we would be filing a Lemon Law Suit. Ford told us to wait the weekend and they would get back to us. Finally in Nov, Ford bought back the car and we are done with it.
Five months of hell. If your Escape works for you, GREAT, but you have been warned, due to supplier problems, there are NO Transmission's available. Escapes are a great vehicle to drive. Just not for RV Towing!!! YMMV
  • janstey58
    there are a lot of people who will disagree with you about that. They have had their transmissions bun up multiple times. Fortunately for us, our car burned up in a house fire. I will never trust Ford on towing 4 down. Even after having a lube pump put on, transmissions have fried. Take a look at prior posts and you will see continuing issues.
    Apparently Ford did not learn from the Pinto.
  • If someone GAVE me an Escape, I would sell it and buy beer and salted nuts.
    Probably cashews.
  • Do you have the Trans. Cooler Pump? Ford bought the rights for the Remco Pump for Escapes and now charges around $3500.00 plus labor. If I still had an Escape, I personally would not tow it without the pump. There has to be a reason Ford bought the rights from Remco.
    JMHO YMMV
  • Comments above not entirely true. Some 2012 Escapes are safely towable after completing the appropriate tech bulletin procedure for lowering tranny fluid, proper tow prep, and maintaining tow speeds under 65mph.
    Got this from Ford: Feb 2012 was the date they changed the transmissions they installed in the Ford Escapes built after that month. And those post 2/2012 built Escapes ARE non-towable. My 2012 Escape was made in 1/2012 and after I completed the recommended transmission fluid level decrease by the dealer, I have towed thousands of miles without an issue. The build date determines tow-ability on the 2012s.
Looking for advice before your next adventure? Look no further.25,178 PostsLatest Activity: Dec 22, 2025
