sheljoy7's avatar
sheljoy7
2012 Honda CRV
Battery runs down without BBconnected. Have wire from MH to Hona battery still runs down after about 2 hours. Suggestions
  • sheljoy7 wrote:
    Used a light one end on ground other on charge line that hooks to postive side of battery light comes on. So I thought I had power battery is 3 yrs old but tested ok at auto store. Help. It's
    All that tells you is you have maybe 12v to make the light work. Take a volt meter and check the CRV battery voltage with key off disconnected from motorhome. Then hook up the charge line with the motorhome running and test the CRV voltage reading again. It should read at least .3 to .7 volts higher. Then set the CRV in normal towing mode and check it's battery again, the voltage reading should still be close to your previous reading.
  • Used a light one end on ground other on charge line that hooks to postive side of battery light comes on. So I thought I had power battery is 3 yrs old but tested ok at auto store. Help. It's
  • lryrob9301 wrote:
    With the units connected for towing and the motorhome running have you actually checked the CRV battery voltage with a volt meter. I suspect it's not being charged.
    I agree. I had the same issue with my 2009 CRV until I installed a charge line.
  • x2 on making sure that there is 12 volt power from the MH to the CRV battery, some chassis may need a fuse installed to have the power at the rear of the MH.
    We had the same problem before installing the charge line, no problems now, even using the Brake Buddy and NOT pulling the fuse in the CRV to disconnect the iMid electronics.
    Ken
  • With the units connected for towing and the motorhome running have you actually checked the CRV battery voltage with a volt meter. I suspect it's not being charged.
