Viewfinder's avatar
Viewfinder
2013 Focus lights and break-away switch
Setting up 2013 Focus auto/pb start for towed. Looking for ideas for lights (battery must be disconnected) and break-away switch placement. Have read about jump-start being used for power. Would like to know what size and brand used. Have elected to stay with Roadmaster brackets as I prefer the wider spread. Thanks for any information you have.
jim
  • I also have a 2013 Focus but it's a 5-speed. Didn't like the procedure for towing an automatic so I can't help there.
    However, I've installed a completely separate lighting system that is powered by the MH. A power line also runs from the MH to a Toad-Charge unit because I use a power line from the Focus battery to power my Even-Brake.
    As for the breakaway switch, I made an adaptor that will use the 2 rods that a receptacle is usually installed to. The MH umbilical cord will run back and into the engine compartment where it will mates with a 5-wire plug.
    I don't want to cut away more of the grill than I have to.
    I'm having the base plate installed Tuesday and when I have it all together I'll send you a few pics (if you send your e-mail address to me at rmmpe@yahoo.com).
    If all is as I expect on the Focus, the steering column doesn't lock so I won't have to leave a key in the ignition.
Looking for advice before your next adventure? Look no further.25,186 PostsLatest Activity: Mar 09, 2026
