timpitt's avatar
timpitt
Explorer II
Mar 24, 2017
2014 ford edge
Do I have to disconnect my negative from battery when towing the edge
  • It is so simple to disconnect. I have the Taurus, same/same. 10MM nut, less than 30 seconds, and you can just reconnect for 6 hour starts. Battery stay muy charged this way and all the settings are saved. And you don't have to drive forward and backward, just run it for at least 5 mins and when you put it in N, just go to D, the R, then N. Shut it off. This gets lots of Tranny fluid in the trans.
    I have 2 Jeeps and the Taurus that I tow. Taurus is the easiest.
    WW
  • I have a 2011 Edge with with push button start. I must say it is a power hog so I installed this.https://rvibrake.com/collections/accessories/products/towed-battery-charger?variant=8804388741
    Here is another great system
    https://www.rvupgradestore.com/TOAD-CHARGE-p/toad-charge-60.htm
    JR
  • The requirement for battery disconnect starts with the 2015 Edge. That's why I ended up with a 2013. After 42 years in high-tech, I want my life to be simple!
  • We have a 14 Edge. The owners manual says to drive in forward and reverse for a minimum of 5 minutes before towing. Repeat every 600 miles. No mention of battery disconnect.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 09, 2026
