rr2254545 wrote:
DownTheAvenue wrote:
How do you expect anyone to know if you need new tires just by answering an internet forum posting? Let me ask you the same question, do I need new tires on my Corolla? They have been on there 4 years and 40,000 miles. Do you know? I don't know about the tires on your vehicle either!!!!!!
There is one sure way for YOU to know, however. Do a little research about tire wear, when tires should be replaced, and minimum acceptable tread depths before replacement. You can easily do this yourself on the internet using Google.
Geez are you having a terrible day =
Well you know, Downtheavenue is right. No picture, and the only description is your brother in law says you need tires.
All tires have wear indicators on them. If the tread is worn down to the indicators you definitely need tires. But this is only one way to tell. How do they handle in different weather conditions?
Mileage is no indicator either. I've replaced tires at 35000 and have had tires that showed little wear and performed well at 100000 miles.
