thankdog's avatar
thankdog
2014 Jeep Wrangler Unlimited Sport - 4 down
Hello everyone - we have a two part question we hope someone can assist with -
We have been towing our 2004 Jeep Wrangler X 2 door Automatic trans for the last several years using a Demco tow bar and base plate with no problems.
We just got a 2014 Jeep Wrangler Unlimited Sport 4 door Automatic trans and would like to tow this one 4 down as well b/c we leave the 2 door in our 2nd home location over the Summer.
In reading the newer model manual it seems a little different protocol from the old Jeep. Can someone who has this same year/model help me clarify the steps and if there is anything I need to know thats different?
ALSO we cannot recall where to go to get the best deal (and correct model) on a base plate for the new Jeep and a 2nd Demco tow bar (left the tow bar in the other Jeep - ooops). Any online recommendations to locate the correct model that fits this Jeep?
Overwhelmed by studying Google searches for three days and getting confused.
TIA
Lynn
  • We tow a 2012 Rubicon. Same protocol as yours. No key in ignition. Transfer case in neutral. Transmission in park. Wiring harness is a do it yourself if you buy a harness from Cooltech at http://www.cooltechllc.com/jeep/jk_tow_harness_kit.shtml. It is plug and play stupid. I bought a used cooltech and Blueox baseplate used on eBay for $135. Used local mechanic to install baseplate. Check on Craigs List, eBay, iRV2 etc.
  • I just bought one and installed the baseplates, wiring, etc. I bought the baseplates (roadmaster) from PPL motorhomes. Their price was as good as anyone else's and I've ordered from them in the past with good results. I got the wiring harness from cool-tech. It was pretty simple to install as well. I ordered the deluxe kit which also came with a negative battery disconnect. I later found out that there is no steering lock so you don't need to leave the key in to keep the steering unlocked. Hence, I did not install the battery disconnect. I did verify by turning the wheel while the key was out and it did not lock the steering. Other than that, I plan to follow the owner's manual for the instructions on how to set up for flat towing. I have never towed my or any other jeep before so it will be a first. I used to tow a Nissan frontier crew cab a while back, so I know what to expect with that much weight. Good luck with yours.
  • Just bought a Wrangler Unlimited also, and am curious to what you learn. Book says to leave key in Acc and disconnect neg. battery cable. What I don't understand is a 14 model does not have a locking steering wheel, so why would you need to leave the key?
