tama2112's avatar
tama2112
2015 Ford Expedition - Largest TT I can pull SAFELY?
Hi Everyone,
I am brand new to this forum and TT's. I've been doing some reading here and its all be very helpful. I'm not sure there is a topic specifically on the newer Expedition so wanted to post here. I am trading in for a 2015 Ford Expedition (not EL) w/ HD towing package. Specs:
4x4 3.5L V6 EcoBoost
GCWR: 15,200 lbs
Maximum Loaded Trailer Weight: 9,200 lbs
Payload Capacity: 1,650lbs
I do NOT want to push the limits of the Expedition. I have a family of 4 and want to get the largest that I can safely tow (both in weight and length.
Could I get your recommendations please?
Matthew
  • tama2112 wrote:
    Hi Everyone,
    GCWR: 15,200 lbs
    Load up the TV with everything as if going to tow. Everything as in
    people, pets, luggage, toolbox, etc and weigh it
    Then take that actual weight, add WD Hitch weight and the trailer
    tongue weight. Then subtract it from your GCWR. That will then
    provide the actual MTWR (max tow weight rating) of the actual weight
    for the trailer
    NOT the 'dry' weight of any trailer, but the ACTUAL weight of the
    trailer...if you do not have the trailer, then use the trailer's
    GVWR that you are looking at. That is the maximum weight that the
    trailer OEM says it can hold
    Matthew
    But...that will NOT have the tongue weight in your calculations above.
    Again, you need the actual weight of that tongue to figure and again
    if you do not have the trailer yet...use the brochure tongue weight
    of that 'dry' weight trailer
    That will provide the percentage range the tongue weight vs the dry
    weight of the trailer...then using the trailer GVWR...use the same
    percentage to give you the number needed to figure the above
    In the end...there is only one person responsible for the setup and
    that is the driver...none of the advisors here has any skin in that
    game...
  • tama2112 wrote:
    Hi Everyone,
    GCWR: 15,200 lbs
    Matthew
    you're leaving out the most important spec, PAYLOAD capacity from the yellow sticker on the driver's door.
    ESPECIALLY important on SUVs, since they usually have lower payloads compared to their towing capacity.
    you'll run out of payload capacity WAY before you get close to the max towing capacity.
Looking for advice before your next adventure? Look no further.25,187 PostsLatest Activity: Mar 17, 2026
